tflnemesis
Hi,
Our toilet has developed a leak in the pipework leading to the cistern. Atm I have stripped out the toilet so I can get to the pipework and give everything a chance to dry out (we have a toilet outside so isn't an issue).
The problem I have is that whoever fitted the compression joint originally overtightened the joint and has deformed the pipe around where the olive sits. I have so far tried just nipping it up, replacing the olives and completely replacing the compression fitting all to no avail, the joints still seep, a vast improvement on the original but still not watertight.
The pipes are very close to the floor so I have limited choices about re-piping it, without ripping up the floorboards, which will mean taking out the partition wall between the bathroom and toilet as the joists run the wrong way for me to be able to cut the boards and secure em back again.
I have a feeling that I need to get soldered joints in, but the soldered joints aren't big enough to take the place of the compression joint, so I will need to extend the pipes using small pieces of pipe and joiners.
The circled parts are where i have seepage.
Is this going to be possible? What issues will I have with so many joints being so close together?
Is there any way I could repair the compression joint without resorting to soldering? I have tried some ptfe tape around the olives and that improved it but not by much and I don't trust the ptfe repair.
The measurements in the drawing are of how much pipe is showing once the compression joint is removed. This all 15mm copper piping btw.
