Omniata
- UK
Post mixing has been attempted by other firms and failed miserably.
The two components need to be intimately mixed prior to contact with the substrate or you get a sticky runny mess.
It takes about 5, maybe less, seconds to react before it gels, then foams. If it doesn't gel properly it's a nightmare to clean up and rectify.
You could use two hozelock garden sprayers connected to the foamseal nozzle/sprayer, but "adding solvents" is a tricky business.
You could use methylene chloride, but it would need to be less than a couple of percent or it would affect the mixing and "blowing" or "rise" of the foam mixture.
Best bet is to do it "warm" with the components heated to about 50°C, with no additional solvents. But you'd need someone stood there keeping the pressure up on the garden sprayers.
There are air pumps designed to pump from drums at high pressure, but again it's down to cost.
Single component foam was trialed many years ago, but for anything thick, over 25mm it doesn't cure properly as the moisture from the air can't penetrate deep enough.
It reacts or blows too quickly too as it's nearly 50% aerosol, wth an extremely low NCO content so it appears to have set relatively quickly, but doesn't complete for 24hrs.
The dual component systems fully react within about 15 minutes, dependent on mixing.
it is just in the vid the gun seems to mix it at the nozzle .
as long as it's mixed before it leaves the nozzle it's fine, it's a right pain, the flow rates are ridiculous!
