daedalusminos
- Norwich
Someone might be able to 3D print you one from TPE.
The ridge is original, that's what does the sealing. A plain one would work, but not so well, I know this as I've turned it over & tried it, this means the clearances are incorrect.Is the ridge original? Or is it a deformation?
I'm asking because I replaced a tap washer the other day which had an identical ridge - and was replaced by a normal tap washer.
I tried that, but the flow of air picked up the o ring & it's now somewhere inside!What about trying a two part construction, Rubber disc + 'O' ring to form the ridge?
I will ask around, I don't know anyone though.Someone might be able to 3D print you one from TPE.
