You've got one of those fancy grip style 26's haven't you with a big chunky body?
I'm old fashioned and think mig torch bodies should stay on mig torches, I expect you would find this style of 9 to be more comfortable...
With a simple handle design...
Taking into consideration the lengths of runs, material thickness and your interest in the process I strongly advise against wasting money on buying a wp9. If you buy a cheap one you'll be lucky if 90 amps ac doesn't kill it and if you spend money on a ck or like then you've done over £100 for (maybe) 100-120 amps ac and that is seriously limiting if you have 200 amps on tap. You can build a basic cheap cooler for £100 and buy a parweld wp20 for £80 which is a faaaaaar better introductory way of reaping water cooled benifits. I can advise on cooler building if your unsure As ive made a few nice ones and you could use your new found skill to make the tank. I can only imagine your going to get advise on running a total loss cooling system next and tap off your supply. DONT do that. Not only is it a waste but tap water will eventually ruin a good torch. Water cooling is the best move you could make for your kit and it doesn't need to be expensive.
) I expect you will find it better... My first cooler was a 1 gallon bucket and a small gear circulation pump. Doesn't need to be anything fancy.Yep. both those torches look gash to be honest.... I'm not a fan of those style at all. I will bring a straight handle style 26 with me for you to try (I'm not lugging the cooler and wp20 into the car) I expect you will find it better... My first cooler was a 1 gallon bucket and a small gear circulation pump. Doesn't need to be anything fancy.
It's such a simple taskNo doubt ill be in touch for some help along the way when that time comes.
