Phil Pallot
New Member
Appreciate it if anyone can advise where to source the anti stone chip paint used in the painting tutorial-Thanks
ive found most folk call the sticky underbody stuff shutz ...and the overpaintable stuff stonechip
I have found the same thing! Spray stone chip coating over zinc primer in the winter and it sometimes cracks when drying. In warmer weather, it is much less of a problem, and if you apply a "dust" coat or two of stone chip first this seems to improve matters. I think the problem is the stone chip paint solvent dissolves and lifts the primer if it goes on too wet and if the weather is too cold to allow the thinners to evaporate quickly. Also seems to be less of a problem if you thin the stone chip with cellulose thinners.
Try heating your garage and applying some dust coats of stonechip, then let dry thoroughly between each coat.
