Richard.
- Cambridgeshire
(You need this with gas)
This is what I thought cheers Steve. There is Clarke and then there is "Clarke"This is the good one:
https://www.machinemart.co.uk/shop/product/details/151te-turbo-mig-welder
The 152 and 196 are the new cheaper range and suspected not to the same build quality.
It appears the 151 is a tad dearer but like the 135 it is one of the decent Clarkes that will last for years.
You can't really cross mix the wire,it defeats the onbject of the gas welds being smoother and cleaner to apply to the metal
Agree 100%, I thought that was the one I had linked to...had not had my morning coffee...that's my excuseMy money would be spent on this one. More power and buttons to play with -> https://www.machinemart.co.uk/shop/product/details/mig151en-turbo-no-gas-mig-welder : £250 inc VAT.
Use it 'Gassless' when a quick fix to [insert broken thing of choice] needs a quick fix.
Deffo use Gas when doing the bodywork, and keep the roll of fluxcore for building a wood burner :/
*As your doing a mini you with be proficient with 'plug welds' by the end!!! Just thinking aloud that fluxcore may be useful for such; seeing as its one pull of the trigger to form the joint opposed to the 'Stop/Start' technique on 'runs', so perhaps the slag inclusions may not be a factor and hotter weld pool may be of benefit?
**Never used fluxcore so that is open to debate![]()
Very true but in fairness I have heard from a happy owner of one of the cheaper Clarkes but not heard any negatives, except I think that most of them have poorer lower amp settings than the originals.This is what I thought cheers Steve. There is Clarke and then there is "Clarke"
You mean using it gasless for the plug welds may be easier because of the higher temperature and the flux core cools it better rather than having to stop start with gas?
