robertbruce
heya all, i hope everyone has been well...
I am welding 25mm 2mm thick RHS
machine is a supercheapauto SCA 180AMP MIG
i am using .9 flux core for this job, no gas, polarity swapped, voltage setting on1 (1-6) and amp (wire) 3 (1-9), Heaps of spatter, wont pool, wire speed erratic. Pulled it down to the liner, very luittle air getting thru wire liner... hoping to go down to .8 to solve feed problem?
1. which is the better wire to buy?
https://www.bunnings.com.au/weldcorp-0-8mm-x-0-45kg-flux-core-mild-steel-welding-wire_p6330052
https://www.bunnings.com.au/cigweld-0-8mm-x-0-45kg-gasless-flux-cored-welding-wire_p5910624
2. did i do any wrong putting .9 wire into when .9 is the max? I got down to the last few meters and am having huge wire feed problems...i am hoping .9 will help it...
