cheb
- Ostdeutschland
How do you rebore a horse (please don’t answer that, I don’t think I want to know...)![]()
It's a hard job but some has to do it.
Still has a mass of one ton wherever it is . . . just on the earth its weight would be 980N ish . . . some of us are waiting for our super duper IT and quality depts to force a change to our drawings to add weights . . . and they are going to be very surprised at the actual numbers I think . . .
Wot he said^^. Plus with a pump system you can automate the whole thing with a few cheap float switches, solenoids etc. Push a button, go off and do something else while the tanks do their thing. Push another button and they do something else. You’ll probably save more in time (which may be worth more to you/your client) than you will ever hope to save in energy if you design it right.A quick google and fag packet calculation; here's the first 800l/m pump I found and it's only 400 watts, that'll do your 4000L tank in 5 minutes. 400 watts for 10 minutes is 0.07KWh, apparently the average price per unit of electricity in the UK is 15 pence so a full fill/drain cycle will cost you a single penny, is it really worth messing about with massive rotisseries, buried sumps, lifting gantries and talking about outer space for some reason for that kind of saving?
Why not have a small hydro electric generator on the outlet of one tank. As water is discharged it generates electricity which charges a battery. When you need to pump, use the battery ?
Just make sure you calculate the flowrate at the head height needed. That pump only has a max head height of 3m, no idea what its flow rate is at that head... But likely enough to get it done in 20-30 minsA quick google and fag packet calculation; here's the first 800l/m pump I found and it's only 400 watts, that'll do your 4000L tank in 5 minutes. 400 watts for 10 minutes is 0.07KWh, apparently the average price per unit of electricity in the UK is 15 pence so a full fill/drain cycle will cost you a single penny, is it really worth messing about with massive rotisseries, buried sumps, lifting gantries and talking about outer space for some reason for that kind of saving?
