I tried grinding the spots down before seam welding the joint, and it improved the weld at the spot, but I haven't practised in 2 weeks, so my consistency sucked. Bits were too fast, and then I overcompensated and blew a hole
More regular practise required before I try the positional stuff (or 1.2mm).
If I get some copper to back the weld, would it be feasible to run beads on 1.2mm? The first bit of welding on the car will be the floorpan, so access to the back is easy. I don't want to run before I can walk, but it would be nice to get something done on the car before easter!
.......well done on the welds ,certainly coming on ,use your ears as well, can help identify problems....looks like you could bunch those tacks up a bit though,aim at the front edge of the cooling tack
