Either cast a re-inforced concrete ring beam around the top of the walls or fabricate a perimeter in steel to tie the top of the walls together and resist the spreading action of the roof.
Without knowing the dimensions it all guess work, but i would go with a universal beam around all four sides of building sitting in the centre of the 6 foot wall.
Bolted together then roofing steel work siting on top of UB.
OP, a number of members have taken their time to offer helpful suggestions and ideas, I would like to think you plan to return to the thread with how the task was achieved otherwise I don't really see the purpose of it.
In fairness this was posted as "Just for fun for some ideas" so a structural engineer isn't necessary in this case, I'm assuming as a 'Live project' that this has already been done and that the OP is just interested in what other peoples' approach would have been....no harm in that we see similar posts regularly.
Attach a large balloon to the roof and fill it with enough helium to fully support the weight of the roof.
there is no right answer and obviously no wrong answer
And the two correct answers in this particular job were
Ahem .....![]()
And that was the funniest suggestion of the topic, how much helium have you got.
There are a fair few stadium/factory roofs supported by positive air pressure in the building courtesy of a great big blower fan....although to keep a normal roof up they might have to be enough pressure so that when someone opens a door your eyeballs bulge out.
leave it to a structural engineer / architect team to sort out.
.........A little unfair that OP with his track record has lit the touch paper and then vanished
he did think it had a familiar ring to it.
I'd simply copy the design of my own concrete shed, built in 1949.This is merely for fun and for people to make suggestions, there is no right answer and obviously no wrong answer, so what would you do and how would you approach, and resolve this minor problem?
This is a live project which is currently part way through.
This is an industrial building which is two storeys high, with a pitched roof and loft to give it three storeys, and we have to make a roof for it and erect it.
The walls are cut stone and 6' thick and are structurally sound, but we cannot place roof trusses directly onto the stone as the weight would cause a "blow out" which is the weight of the roof forcing the top stones out and the roof collapsing, and we cannot use tie bars as the roof space has to remain open.
How would you approach it and what is your solution?
