Amps for 4mm rods
  1. Liam567 Member
    132
    Ireland
    Hi lads just out of curiosity what size welder would I need to burn 4 mm rods .
  2. Memmeddu
    Memmeddu Member
    2,954
    Italia Sardegna
    4mm 160A up to 220A I believe
    metalmelt and James1979 like this.
  3. James1979 Forum Supporter
    1,607
    Orkney
    Its more about duty cycle to be fair. My Thermalarc 175 will do about a rod and a half and wait a while and it'll do it again. My diesel welder will burn them in hot all day and not get too far above idle.......
    metalmelt and Memmeddu like this.
  4. rory1
    rory1 Member
    1,183
    Macclesfield
    I usually start off about 175 for a 4mm
    Memmeddu likes this.
  5. metalmelt Member
    595
    UK
    It really depends on the electrode, some will melt at about 90 amps and this can vary with AC or DC and will give little penetration, while others need around 200 amps DC to give a decent weld; it also depends on the welding plant and its output and duty cycle as a domestic plant will quickly trip out on thermal within a few rods.
  6. Feet 'n Inches
    Feet 'n Inches Out of the rat-race at last
    364
    Devon, GB
    My preference would be an oil-cooled machine, if you're in the workshop, no problems with duty cycles. Trouble is, to run the kinds of current 4mm rods need you'd need a 3 phase supply. I don't know much about inverters but if you can find one that handles the kind of current, suggested by @Memmeddu, with a decent duty cycle you might get away with a dedicated 20 amp circuit on single phase.
    Memmeddu and James1979 like this.
  7. metalmelt Member
    595
    UK
    Many DC inverters of around 200 amps or higher will easily handle them and 5mm.
    You have a choice of DC invertor machines running off 240 single phase around these currents, albeit over 13 amp input.
  8. Memmeddu
    Memmeddu Member
    2,954
    Italia Sardegna
    My inverter will stay in the 13A only if under 100A output current.
    I can drain 16A continuously out of my powermeter , and up to 32A for 2 minutes .
    I have a separate dedicated circuit for welding
  9. brightspark
    brightspark Member
    31,750
    yarm stockton on tees
    32 amp single phase supply for a 180 amp oilcooled
  10. Turbo Member
    3,856
    Fermanagh, Northern Ireland
    My oil cooled pickhill will happily run 4mm rods at 165a running on a 16a single phase supply.
    brightspark and Memmeddu like this.
  11. metalmelt Member
    595
    UK
    My inverter will run 250 amps at 16A MIG and 220A in stick.
Advertisements
