truckdoctor
I make small model cars from sheet 1mm aluminium for the body and so far have bolted panels together but would like to spot weld. Is there any kit available that's price friendly as this is just a hobby.
I believe that the trick with aluminium is to sandwich it between two thin sheets of steel (maybe stainless, I don't know). Most of the heat gets generated in the steel and melts the aluminium under the spot. I've never tried it though.You'll end up with a blob of ally, is my thoughts. Surface tension has the tendency for the edges of a puddle to pull together, making spotwelds difficult, in my experience.
The sandwich technique works, and I've tried it....I believe that the trick with aluminium is to sandwich it between two thin sheets of steel (maybe stainless, I don't know). Most of the heat gets generated in the steel and melts the aluminium under the spot. I've never tried it though.
I've been meaning to try it with my little microwave oven transformer spot welder. I'll see if I can find a 'round tuit' in the next couple of days.
Thanks, yes I've seen a video of these for welding connecting batteries together and I'm not sure they will have enough power.What about Something like the battery cell welders
Like this, a lot of choices out there, presume it is very thin alloy
Thanks, i look forward to your results.I believe that the trick with aluminium is to sandwich it between two thin sheets of steel (maybe stainless, I don't know). Most of the heat gets generated in the steel and melts the aluminium under the spot. I've never tried it though.
Was demonstated to the class during my Contour Autocraft lessons in panelcraft. Smallish spot welder (like the machine mart one) run at full power if I recall correctly. This was 2 pieces 1 mm aluminium sandwiched between 2 pieces of 1mm cold rolled steel. Perfect joint every time.The sandwich technique works, and I've tried it....
