Finally got it together, argon, 0.9mm tips(no 1.0mm in stock)
and time. Oxide all cleaned of and ready to go. First attempt and the tip blew out completely to the thread(had to drill it out). Next attempt, increased wire speed a little and lost half the tip.
AAAARGH!!!!
Thought it time to change the settings. Wire speed up again and there goes tip 3
. Second last tip, wire speed almost full and power on about half and you little ripper
better weld than I've ever even done with steel.
I'm lovin' this. I even welded more than I needed to just because I could.
Thanks for the tips Malc.
AAAARGH!!!!Thought it time to change the settings. Wire speed up again and there goes tip 3
better weld than I've ever even done with steel.I'm lovin' this. I even welded more than I needed to just because I could.
