Aluminium isn’t my strong point when it comes to tig, however I can get two bits to stick together although I don’t have a pedal so dont have a lot of adjustment. However a pedal is something on by list of things to buy.
Anyway, what I am really struggling with is welding small round parts to other items (which are usually much bigger) for example, yesterday I needed to weld a 25mm ish x 5mm threaded disc to a length of folded 4mm plate. Although I managed, it certainly wasn’t pretty and I found attempting more than a sixth round at a time usually ended in disaster, mainly issues with being out of position and finding somewhere suitable to prop. In the past I’ve tried welding small round fittings (an style weld on) and had nothing but heartbreak. Yes they stick but are usually not air tight, and are normally a bit of a mess. I know practice is a large factor but any other advice? And when attempting some of these jobs I’ve always done a pre-heat on the larger part (couple of hundred degrees with a propane torch) to try and make life easier.
For info I’m using a jasic 200a ac/dc and I’m familiar with the incompatibility of some of the grades.
Thanks in advance
Thanks in advance
