not rude at all,I prefer straight up criticism. But I did practice weld on some scrap pieces and shaped them down with an angle grinder,and the pieces held together strong.without meaning to sound rude the welds don't look too good.
for a second I thought you were calling mecold and blobby
well,the blobby bit is about right
As aboveAre you able to get some similar parts to practice on?
cough,erm it is reasonable. I've welded in a new wing and pieces of panels. And have welded on two brackets under the slam panel for an intercooler.Just out of interest, what is your steel welding like?
I've not really weighed that up,or perhaps I'm doing that without realising.Can you lay down a nice looking bead on mild steel or do you find that a bit of a struggle too?
A novice is about right.I only ask because if you are a novice, alu isn't the ideal material to learn on.
I did consider mild steel but because with it being air/fuel entering in there,I predict rust will occur within.Why are you making the part from aluminium rather than steel?
Looks like it bolts on to flanges on the manifold and carb. I'd have made it from steel, possibly stainless if I was feeling showy.
All that, but, if it's gas tight and on, why not just clean up the worst of the poo, clean it up really well with a SS wire brush and acetone, and smooth it out with epoxy. Spray it silver if you like.
It'll never be a testament to your welding skills, but it should work.
That is correctOne thing we haven't talked about is your machine parameters, I gather you're using a 130A SIP
It is actually 5mmfor 3mm alu means running it flat out to stand a chance of getting enough heat into it
No,I started off cold. I will try the pre-heatDid you pre-heat the parts or weld them cold? A bit of pre-heat would probably help.
So so. After grinding down the height,there was areas that the grinder didn't reach. So I had opted for SS wire brush,works alot betterAre the parts totally clean and oxide free around the weld area? If so did you clean them with a stainless steel brush?
I got the tube off ebayYou said the flange is cut from alu plate but where has the tube come from? It might be a difficult alloy to weld as Runnach mentioned.
Good question. Didn't realise they were numbered,so I'm not entirely sureAlso, what filler wire, 4043 or 5356?
Oh dearQuestions, questions, but the problem is that almost everything you've ever learnt about welding steel goes out the window when you attempt alu.
Yes,I weighed that up and considered getting a platform for the carb to sit on. Even though I could be successful in making the parts,it's the internal condition of the tube. The A/F needs to flow through smoothlyI doubt if it is gas tight and attached, with the weight of the carb, and some engine vibration, changes in temperature etc, my betting is it'll fall off
Yep,it's seems that is the best solution. I think I need to realise my defeatmy advice would be as per Shenion, do it in steel or make up the parts and take them to a pro to get welded
http://uk.youtube.com/watch?v=V_MiGrL9350A non welding related problem i can see. Are you doing what i think and extending the intake manifold at an angle so the carb misses the brake servo. If you are, the rear runner length is going to be longer, you could have fuelling problems, and at worst end up running the rear cylinders lean and melting pistons. You might be better rotating the carb up instead, then you can use two equal 90degree bends. If this wasnt the plan, or if it`s been done successfully before, please ignore this.
glad i`m not going mad after all. better still, if you`ve got the time/effort/probably money convert it to injection, there was an interesting article in Practical Performance Car many years ago expaining how it`s done, probably more hassle than it`s worth.
Yes,correctAre you doing what i think and extending the intake manifold at an angle so the carb misses the brake servo.
aha...that is a good point. Always good to have fresh eyes looking at were I'm going wrong. There's a possibility that the fuel can be monitored per venturiIf you are, the rear runner length is going to be longer, you could have fuelling problems, and at worst end up running the rear cylinders lean and melting pistons.
Yep,I've been looking at that recentlyYou might be better rotating the carb up instead, then you can use two equal 90degree bends.
Yes,a DRLA or an IDF would be the answer. It would mean that I will have to buy a pinto downdraught fanimold. The price I've seen so far is £185. Also,with my intention for turbo application,I've been digging around on info about whether a Weber or Dell would be best suited. I know the Lotus used 2 Dells,there's been mention that webers are up for the job aswell. I do have a couple of Dells,so I can experiment which I prefer.best would be 90 degree bends then sell the sidedraught for a down draught. if its in good condition you shouldnt make a loss. while youre at it get a dell'orto instead of a weber. they tend to be better.
Oh please do,I can then make a comparisoni can give you the ebay address of a dell'orto seller in america who does em half the price of others. thats where i got my quad down draught dell'ortos (IR runner) for my V8)
yeh,I was also considering that. But with it being an ABS unit,it is a drawback. I have considered doing away with the ABS,and put some remote bias boxes in.other option is to remote mount the barke servo
Yes,I saw that article. It did bring a certain amount of controversy,as many do not want to destroy a Classics authenticity. I did think it was interesting,as it would be a means to bring down emissions. But,my aim is to eventually put a turbo on,so it would be a blow-thru setup. Don't know what it is,there's something about an Old Skool style blow-thru setupglad i`m not going mad after all. better still, if you`ve got the time/effort/probably money convert it to injection, there was an interesting article in Practical Performance Car many years ago expaining how it`s done, probably more hassle than it`s worth.
