Lee Patterson
- UK - Hampshire
Looking for some help please guys. I have been stainless welding for a few years and have no problems with that. I recently got a cheap ac welder to have a go at ally welding and am having some problems. I can run a puddle on a piece of ally but I came to try and weld two bits of plate about 1.6mm today and couldn't get started. It is as if the melting parts of metal on each piece repell each other so they don't melt together like when doing steel? I also cannot get the wire to drop in the puddle and run as this too appears to be repelled away? I flipped over one of the test pieces and ran over the inside of a corner joint and could get the puddle to run fine if not a bit flat. But as soon as I have two separate bits to join no go? What on earth am I doing wrong. I have tried varying current up and down. Adjusting the cleaning balance. No joy.
I amean using around 45 amps but have been 30-65 without success.
1.6 zirconiated tips. 1.6 filler rod, 7 litre/min flow on pure Argon. Just using a straight Ac current setup with no pulse or anything. And a no.8 ceramic cup.
Really appreciate some pointers as I have watched videos and read some stuff but cannot see where I am going wrong.
Thank you
Lee
Thank you
Lee
