They will till a point, not enough weight they'll either open up exploding or the square drive will become round not driving
I don't use impacts for tightening up I use a torque wrench for that.What do you torque them Fiat wheel nuts up to? They will be fine.
)I have a specific set for wheel nuts/bolts, they are Parkside and have the Teflon/plastic sleeves on to avoid damagesOnly thing I have found wrong with the cheap impact sets is the od of the sockets, they are a fair bit chunkier than the better brands and some of them wont fit into the wheel nut/bolt holes of ali wheels. Other than that they are good, had no failures.
Bob
You have to remember AliExpress are just a marketplace, the same as eBay, so you're not actually dealing with AliExpress, you're dealing with individual sellers.As a contrast AliExpress are ok until something goes wrong.
Then they are a nightmare to deal with.
They will do anything they can to avoid a refund.
They will give you a partial refund even though you ask for a full refund.
That makes getting a full refund nearly impossible.
In the event of a claim they ask for some daft irrelevant evidence that has no bearing on the claim in hand.
They either employ the stupidest customer service agents or you are dealing with an AI.
They will promise you that the will sort things out but they either do the wrong thing or do nothing.
They ask you to return items to China at your own cost, promising to refund you if the item is faulty. The postage cost is often more than the value of the item.
