it sounds your arc length may be too long... http://www.mig-welding.co.uk/forum/threads/arc-length.7862/ Also covered here... http://www.mig-welding.co.uk/tig-fillet-weld.htmEnd up continuously feeding filler rod in and having to heat one side then the other
ali in the title
Never used helium as shielding gas,What about pure helium?
Helium adds heat as it increases the arc voltage. It's also got a higher ionisation potential which is a fancy way of saying the HF start won't work as well and one of the reasons why it's usually mixed with argon- arc starting and stability. Another is because helium is 'kin expensive being a finite resource that's running out. On the off chance anyone is thinking about it balloon helium won't work, it's air with enough helium to make balloons float or something along those lines
Different BOC alushield flavours... http://www.boconline.co.uk/internet.lg.lg.gbr/en/images/Alushield_LUH410_55529.pdf Air Products just do the one flavour (alumaxx?) i think which is 25 or 30% He
A bit off topic but does it then become TAG welding? Since you're using the gas to add heat to the weld+
