I got a compressor for 30 quid, thought it was a bargain...
so did I the 5W ones with a torch led in the end? they are brilliantI was in aldi yesterday, bought a small led inspection light for less than a fiver including the batteries. Used it in the shed last night, great little thing.
You definitely don't want a saw operated by a foot switch, that's an accident waiting to happen. May be a foot operated stop switch but not one where you could accidently trigger the motor by stepping on something.Just some feedback on the Aldi table saw I bought..in case others are fancying one.
For the money it is excellent, fair bit of power, good cuts and even the guides are good both the straight and angle cuts.
One big negative...very big in fact is the switch, it's tucked away on the panel under the table and not easy to find quickly without bending down to look, it also has the dust cover type fitting so is not an easy switch at the best of times, I don't plan to wrap myself around the blade but am surprised it has no emergency push stop function.
I may look into a 'something' that can be pushed/pressed by foot.
Yeah I meant a stop switch.You definitely don't want a saw operated by a foot switch, that's an accident waiting to happen. May be a foot operated stop switch but not one where you could accidently trigger the motor by stepping on something.
That's what it has now, they are fine when in full view but I don't like it where its positioned.Can you just remove the wiring and install a standard double switch arrangement like dewalt and other table saw producers use.
Something like this if it hasn't already got one
http://www.ebay.co.uk/itm/152026898461
Think it's sorted, mate says he has a big red emergency stop button going spare, may just be ideal.I've seen a couple with a "stop bar" under the edge of the table on the infeed side, looks easy to find/operate when needed. Maybe a bit of fabrication required?
