no the leak wont cause the issue, if you want to be sure run it again if feel the filters they should be cold but i suspect they will be warm after running for some time, are they very close to the compressor nowOk thanks I will try that tomorrow...I have a small leak after the filter I need to replace the ptfe on the fitting could this also be causing condensation in the line?
