I would have thought CFM was far more pertinent?
Why 2 Parm?
Volume is totally irrelevant. It's the fact that I'm reducing the line pressure to suit the gun. If that pressure is lower than the masks requirements, there's insufficient protection irrespective to the 45 CFM free air his compressor supolies
Delta9. Interesting figures. If I'm reading it right im starving the mask by reducing the line pressure. Therefore I would need to inceease the line and reduce the gun input. When I was spraying full time I ran the line to 50 PSI at the gun and that seemed to give a positive pressure in the mask mind
I can use the airvisor 2 with a gti pro with an H1 aircap approx 15.9 cfm from a 29 cfm fad compressor without the low pressure whistle going off
Presumably through a Y piece. So what pressure do you run the line to the belt?
