Hi there,
I have been doing some reading for getting myself an air fed mask setup in order to paint using 2K.
Based on my reading I need :
- a compressor which does at least 7-9 CFM to run the mask.
- an air feed mask about 7 CFM.
- a 3 stage filter.
I already have the following:
- a compressor 2hp to run the gun which is rated 11.33 CFM air displacement, so probably about 7CFM air free delivery.
- a Standard regulator.
- a couple of copper wire to bring the air in the garage.
- the compressor is in a separate room behind the garage.
Here is my couple of question and idea to achieve the perfect setup regarding my DIY condition.
- I am planning to paint outside in the driveway under a "close" tent. I am wondering about the risk for the neighbour?
- The tent will be at about 7 meter from the compressor, and I will have an extra 10 M hose from the garage to the tent. Is it good?
- I am planning to respray the detachable panel (wing, door, ...) in the garage, any issue doing this?
- The small compressor is at the moment in a room behind the garage which is isolate from the garage apart from the hole made to pass the copper pipe.
I will need to push that whole with some polyurethane expanded foam in order to paint in the garage?
- As the room in the back of the garage is too small for a second compressor I was planing to build a metal box beside the garage to store/use the second compressor from the their. I will obviously connected with this other one.
- I have a shed behind the small room at the back of the garage, would it be better to store it there?
- Does the 3 stage air filter can be in the garage? and me painting in the garage at the same time?
Any recommendation on air fed mask and 3 stage air filter welcome.
Thanks for the help
- a 3 stage filter.
Thanks for the help
