advice
  1. Poke Member
    25
    Rotherham england
    Hi could I weld a 12mm diameter rod to 6 mm plate with 180 amp machine
  2. Wozzaaah
    Wozzaaah The wizard of woz Staff Member
    14,400
    Wiltshire, UK
    Yes, should be fine if you have the machine set high.
  3. eLuSiVeMiTe
    eLuSiVeMiTe Forum Supporter
    9,697
    Bedfordshire England
    Would have thought so beveled all around.
    What's it's application.
  4. Richard.
    Richard. Member
    18,207
    Cambridgeshire
    Depends what that rod has got to withstand
    the rod isn’t the problem, as rightly said above you can bevel it and due to the low mass off the part being only a bar your not going to struggle to get heat into it. The 6mm plate however is a different story. Maxed out you’ll punch into it slightly but your not going to get amazing fusion. If you had more current on tap 200-250 you’d get into a spray and focus that arc on the plate letting it wet naturally on the rod. In your case that probably won’t spray so your arc will be concreted between both parts and the fusion going into the 6 will be limited. If it’s not undergoing much force it will be ok.
  5. slim_boy_fat
    slim_boy_fat Forum Supporter
    How is access? Could you drill the plate and plug weld from the rear in addition to the bevelled front weld? :dontknow:
    Parm, Yamhon, Dcal and 1 other person like this.
  6. chunkolini
    chunkolini celebrity artiste
    8,593
    Swansea
    I have just done a bunch of 20mm bar to 6mm plate joints with no problems, these were supporting about 15kg trees 2m tall.
    I did give one a severe kicking to see if it is up to the job. No problems.
    I bevelled the end of the bar and welded in a deep fillet weld, using runs about 30mm long going radially around the bar.
    looks attractive and is not going to fail. Done using a 180 amp Mig machine on full power.
    Parm, Yamhon and Wozzaaah like this.
  7. Poke Member
    25
    Rotherham england
    Thanks for advice , time to give it a go me thinks
  8. Yamhon Member
    929
    Earth
    Just a thought; could you preheat the plate to aid fusion?
  9. pedrobedro
    pedrobedro Man at Matalan
    9,942
    CX Derbyshire
    From the man with the speech impediment, "You can't say fairer than that" :D The "severe kicking" is now a recognised test for bar attachment to plate but must be done with a size 9 or over and toecaps
Advertisements
