Onoff
- Sevenoaks, UK
I decided not to apply an epoxy (or comparable) coating to the concrete floor in our new garage. I wasn't interested in a pretty, man-cave-style floor, bur just wanted to protect the concrete from salt, oil, grease, etc., and also prevent or reduce dusting. Instead of a coating, I opted for a two-step penetrating concrete treatment.
The first step was the application of a penetrating lithium silicate concrete densifier and hardener/strengthener. The concrete had cured for over a month and was clean and very dry before applying it. This is what I used (I would think that this or similar products should be available in the UK):
https://assets.ctfassets.net/muyees5bu8n0/7A6CiwnF0WYcwk1uB7mDxf/fb8aa01ffb4ab4083f529d0efe88a131/4500_TDS_LEED.pdf
After that was thoroughly dry, I applied a penetrating hydrophobic and oleophobic sealer that repels water and oil and protects against salt damage:
https://assets.ctfassets.net/muyees...c28b23765eba9a743a76285ffa7/8510_TDS_v.5_.pdf
Note: This sealer might prevent some types of adhesive, caulk, or coatings from sticking well to the concrete. I put a few drops of epoxy on the sealed concrete to see what happens, and the cured epoxy popped off easily with a putty knife. I figured that meant that it's doing its job. Neither of these treatments changed the appearance of the concrete very much. These were fairly expensive products, but I think they should be worth it in the long run.
I've only done half of our garage floor so far. I need to move a bunch of stuff off of the other half of the floor to do that half, which I plan to do before winter.
Wow! I take it you can't get SBR there?
