madkayaker
Pro sparkey Pro Welder
I think its time to get an electrician that can do the job properly for you
earth from metal box to consumer unit .as in the diagram in above link post . an earth rod is not required in garage unless it is a tt supply . thats another post . loose it not neededI will not have enough lengh on the armoured cable to reach the consumer unit if I removed the large switch next to consumer, if I fit a metal box and gland then fit another box inplace of the switch to joint wires from consumer to armoured cable? when fitting metal box in garage I run earth from this to consumer? Do I leave the earth that goes from consumer out into carpark?
u can double them up if the extra capacity is needed. eg 2,5mm becomes 5mm and so onOk will get earths at both ends sorted and hope it allows me to use my 16a plugs. A previous owner installed this aswell as bodging alot of other things around house using what he could get his hands on, I have some pots on my wall with lights inside, two have the correct size wire, the other is a large cooker wire!
I mentioned that the armored cable is 4 core but only 2 wires are used, is there any advantage connecting the wires together so I have 2 lots of 2? Or leave it as it is, I dont know the size of the wire
That's dodgy as hell, if you fused it for both combined and one of the cores was broken though damage or the connection came loose you have just created a nice fire hazard and will have great fun explaining that one to the insurance company.
its not dodgy at all doing it with swa cable .all the cores are enclosed in the same casing and are the same length
Parallel conductors are common practice within industry
correctParallel conductors are common practice within industry
who mentioned chockblocks in the postOn larger stuff with proper terminals yes. You wouldn't do it in your house with choc blocks though, well I wouldn't anyway
have u ever heard of service conector blocksOn larger stuff with proper terminals yes. You wouldn't do it in your house with choc blocks though, well I wouldn't anyway
who mentioned chockblocks in the posthave u ever heard of service conector blocks
