dan.taylor.1
General Tinkererer
- Kendal, Cumbria
Hi folks
Wanting some advice on which type of fixing to use for the posts of some railings, they will be fixed via a plate to a concrete block wall (100mm solids with 100mm poured concrete between the two skins with steel in the concrete and ties in across the two skins).
Not had much luck with the sleeve type that are basically an expanding nut a bolt goes into, or the really coarse thread bolt type. I have. Used the knock in type with a sliding tapered bit that grips as the nut pulls it up, but only used the massive ones in the floor not horizontally.
Dan
Dan
