the repair man
Hi all, I have been having a problem with my car for a few months now. Thought I had tried everything. I clearly haven't tried one thing, the one that will fix it.
I was hoping there might be someone on here that knows the component theory, rather than just the mechanics.
My car has a bad knock/vibration under acceleration above about 50mph, It used to be 40mph, but since some recent work, it is now above 60mph.
When I say bad, with the windows half way down, they slap the car violently.
It does it in a straight line, steering makes NO difference. Have rotated and balanced all the wheels. No apparent engine mount failures. 4 months ago I changed the o/side driveshaft. Recently the nearside ( not new unit but guaranteed )
The vibration manifests itself in the n/s/f wheel I think. Its a toyota corolla T sport. Today I jacked the car up on the A frames, so as to load the suspension like normal running. I ran the car, starting in sixth gear to put a torque load on it, and up to about 150 mph. The knock was apparent in the car but not from outside. What I did notice and don't know if its relevant, it was only ever the n/s wheel driving, unless I put considerable load on it, then the o/side would kick in. Does this suggest that the car is trying to drive mostly on the n/side? That would no doubt cause trouble, but I don't understand differentials well enough to know. ( the o/side wheel is free to turn by hand with no drag.
2 other notes. With my father in the passenger seat, the vibration is reduced considerably ( he is about 16 stone )
If at any speed when its vibrating, I reduce to a neutral throttle, it disappears, but a slight incline or torque load and its trying to start an earthquake.
Please help, I have had the guts out of this car and still no luck!
Sorry for the long post, but thought I would be thorough!
