Projects14a
Hello all,
I bought a power craft 2.5HP compressor from Aldi over a year ago and as its only 24ltr, i could do with increasing the capacity. Obviously im not going to weld a section into the tank, but was thinking of plumbing in another tank either from a dead compressor or a calor gas bottle.
Would this be ok? Obviously im abit unsure whether the motor/pump could manage to cope, at 2.5HP, i figured it may be ok, max duty cycle states 50% in the manual for a maximun of 15 minutes.
Think it fills the 24ltr tank in approx 3 minutes, so can i assume that i could effectively multiply the capacity by less than 5 to stay within the max duty?
Other spec's are:
Max Working Pressure: 8 bar/ 115psi
Pump Air Displacement: 9.5CFM
Motor Capacity: 1.87KW
Motor Rotation Speed: 2850rpm
Thanks in advance!
Other spec's are:
Thanks in advance!
Ooops
