Doesn't the arc & air maintain the plasma?No. It won't work.
What would you use to maintain the plasma? Hint: something that won't burn....
I guess I'm missing something here. Can you explain a bit.
I was thinking of using a plasma torch in place of the tig torch. Just using the inverted power of the machine & supplying compressed air.
I have a plasma inverter & know some machines have both in one. My plasma cutter is a 40A while my tig is 200A. This is what had me wondering.
It won't produce a clean cut.Thanks. Good information guys.
I'm still wondering if it'd still do thin steel.
Thanks. It was all worth that laugh.Yes. Heck, mine does it all the time even when I am welding!
It was a good question. Like I say. The power sources are very different but plasma and Tig as actual processes are not that far apart at all. I've done plasma welding as both a manual and automated process and it's pretty much Tig welding with a long arc. Great as a seam welding process too on an auto system.Thanks. It was all worth that laugh.
