Time to switch to oxy propane for heating and cutting , Tig for welding and brazingView attachment 262772!! Today’s bill.
Btw,I don’t deal with BOC,just my gas supplier has to get them wherever he can.
With propane you can definitely braze , cutting is better than acetylene but you have to keep a longer flame length between tip and piece than acetylene.Maybe.thing is ,I learnt to braize and gas weld 42 years ago,then cutting 6 years later,so hard to change,would like to try,how about mig braizing,maybe evening class at Hereford?apart from money saving what other ad/disadvantage?
You need to go to better nozzles like Koike or ESAB HD nozzles to run propane and get the best quality cuts. Normal PNM nozzles are junk.Propane makes a lot more dross than acetylene and leaves a more jagged cut. We tried it on a profile cutter years ago and had to go back to acetylene as propane was not tidy enough.
is that for a full large size bottle of acetylene£54 + vat here nick. Ring boc up and get onto your area manager and complain. Also get the handling fee waived.
Welding I think it's impossible.
Advantages
More calories so bigger parts can be heated quicker than acetylene
Way safer than acetylene (acetylene can start a fire even inside its bottle without any external cause )
Cheaper
Disadvantages
Less heat it reaches roughly 500°C less than acetylene
Dedicated tips
Can't weld
BOC industrial cylinder yes.is that for a full large size bottle of acetylene![]()
I paid about that for a 6Kg Propane in September / OctoberView attachment 262772!! Today’s bill.
using oxy acetylene for welding and the odd heating you dont use much and it goes a long way its the oxygen that you use a lot ofIf you don't use much acetylene some of the rent free places can supply acetylene, hobbyweld is one.
