DAPPH
as dyslexik as I'm daft
I've cut it with a jigsaw, hand held circular saw and table saw. The way carbide blades cut, there's very little heat build up. They all cut fine.
Be sure you want to use it for that though, as mentioned, it's heavy. Also performs terribly when hot, a hot day, sees it expand and buckle and sag all over the place, let alone if it's in direct sun!
Thanks for that , I noticed the sag where the sheets of board over hung the pallet for six months or more during the hot summer .
Luckily the rails of the staging have an inside continuous 30 mm x 3 mm lip on each of the 3mtr sections and have flat 30 mm wide welded in cross members every 400 mm and a cental flat bar theb length of the 3mtr section , so in effect like six point supported panels of 400 x 250 mm .
If it's riveted down with big flat head rivets like the resin impregnated ply boarding I'm replacing , it should stay reasonably stable & flat . It does not have to be , " As flat as ****-on-a-plate " (
