No, its at equilibrium at that speed for a sustained time.Does it work for a short time only? Do they get up to wind speed and then use drive from the wheels to spin the propeller slightly faster?
Hi Rick, thanks for taking the time to join the forum and explain things properlyIf this is an intelligent discussion, there must be hundreds of extremely stupid discussions around the net
What I struggle to buy is the limitless acceleration idea, even in a perfect, loss free, perfect propeller, perfectly grippy tyres, indestructible design scenario. What's that limit? Is it really just down to practicalities and with a super perfect situation, you reach the next limiting factor, like supersonic wing tip issues or the fact that, while there's an ocean of wind energy available, it's not infinite
at some zillionty mph, eventually, you'd slow the wind down so much, you'd run out of a useful wind/land differential to exploit....
is there some other theoretical limit, like the Betz limit for wind turbines that helps make it make sense?
2 sailboats tacking around a cylindrical plane is a really good way of visualising the principal.
In real life this is impossible because any physical body size has a drag coefficient above zero.What I struggle to buy is the limitless acceleration idea, even in a perfect, loss free, perfect propeller, perfectly grippy tyres, indestructible design scenario. What's that limit?
People often ask whether we claim limitless acceleration, and we definitely don't. It's pretty easy to say how fast it will go steady state as a function of wind speed. You could certainly do better than our 2.8X record without too much difficulty, but it would be hard to imagine anyone ever doing 10X wind speed downwind, steady-state.
On the other hand, it's interesting that it can theoretically do *any* multiple of wind speed IF the efficiency could be made arbitrarily high and the wind was slow enough (because if you start getting the blade tips up around Mach 0.3, you get compressibility effects that cause inefficiency that will limit you).
Yes of course. But for the purposes of discussion, I guess we assume an unlimited playa and a steady wind.
We're not subject to the Betz limit in its downwind configuration because the rotor is a propeller rather than a turbine. In the upwind configuration, we are subject to Betz, but in that case we "seemingly" violate that limit because we're not sitting still waiting for the wind, but going out after it. I say "seemingly" because we clearly do not violate any of the well known laws of physics and aerodynamics this thing is based on. We still don't get something for nothing.
But...
Imagine the Blackbird, only with a perfectly efficient drivetrain from wheels to propeller. Imagine the propeller works perfectly without air compressibility/dynamics issues at any air speed. Imagine the whole vehicle has a zero drag coefficient.
In this case, you have a constant source of energy feeding the acceleration of the vehicle, with nothing to oppose this force. Therefore it will keep accelerating.... Faster and faster... This was Fizzy's point.
In real life even if you could zero the losses to friction/drag (which you can't) the propeller would lose effectiveness at a certain speed and the vehicle would reach equilibrium at a point dictated by the fluid dynamic properties of the propeller... If that makes sense?
Howdy folks. A friend sent me a link to this discussion. I'm Rick Cavallaro. I designed, built, and drove the Blackbird. I've seen hundreds of discussions about it, and this has to be one of the most intelligent I've seen so far. If there are any questions I can answer, I'd be more than happy to try.
It's a very common misconception that the propeller produces a sort of high-pressure air-buffer for the tailwind to push against (if that's what you mean). The reality is that the airflow through and around the propeller is identical to that of a Cessna in straight and level flight. Once past wind speed, the propeller is operating on the air entering from the front of the vehicle. But it has a huge advantage over the wheels since the propeller is advancing through the air more slowly than the wheels are advancing on the ground.
We did make the vehicle as efficient as possible within our means, but you can have a surprisingly inefficient vehicle that will still go faster than the wind - as long as you don't want to go a lot faster than the wind.
With respect to the narrow speed range, it's actually not terribly sensitive to that beyond destroying itself, and not being able to work successfully in too light of a wind (about 8mph in our case).
). Also there is a bit about trees I'm not too sure about!
) and I am standing still in a still wind while the planet rushes past my feet. The wind as a sentient being, sees the ground as an inconvenience as it is zooming along. In its frame of reference, the ground is "getting in the way" causing drag when suddenly it bumps into a tree on a skateboard and in that section of otherwise rough drag inducing groundplane, it can slide forwards a LOT more easily remembering that if a root touches the ground, it suddenly wants to lurch forwards. Little does it know some clever human has stuck a mechanism inside to nick some of that power otherwise lost to drag and instead turn it into a spinning prop.Imagine the whole vehicle has a zero drag coefficient.
As I repeatedly said, it was a theoretical scenario that is impossible in real life for multiple reasonsHow is the wind going to blow it along?
As I repeatedly said, it was a theoretical scenario that is impossible in real life for multiple reasons![]()
2m impeller at 2 rpm - I reckon that’s nowhere near Mach 1?You only need to spin a 2m long prop at just over 2 rpm before you reach mach 1 at the tip!
I imagine the gearbox/diff and shafts have quite some force through them given they're almost levering off each other.
2m impeller at 2 rpm - I reckon that’s nowhere near Mach 1?![]()
0.468 mph?Work it out...
I agree though, it is surprising.
