"My mother in law, she's a"Roger Mellie?
My first thoughts when I saw this thread.Was it Roger Mellie?
And you get what you pay for...The old dictum goes....
If it seems to good to be true....
It probably is.
if u want a multidrill just use the bosch ones from screwfix when they get a bit blunt just sharpen them on a green wheel on grinderbeen meaning to ask...........have you seen Borat?Yes but you wont get a set for 40 quid. Normally used by cnc'ists as they are too veasy to chip or snap with manual drilling.
I use the small size stub drills for pilot drilling. They dont bend or go off sideways like a normal hss can.
3.1mm were on clearance for a pound so I got a few.
www.zoro.co.uk/shop/cutting-tools/carbide-stub/carbide-straight-shank-stub-drills-metric/f/115?productsDisplayed=100
The ones on telly would have been cheap tipped drills, masonary bits reground. Proper carbide for the demo?
A decent hss cobalt set would be better choice for most on stainless, and plain hss for everything else.
Borat, the second one......been meaning to ask...........have you seen Borat?
Classic bait and switch.I have seen the same guy's at car shows....
I said I'll give him the money but I want the set he's already used.....
OH u cant have them because they have been used.....hahaha...
said I dont care, picked up his box and offered the money.....he snatched the drills outta my hand and said keep ur money....
so I emptied his little stall.....
obv not the same qual of drill sold as the ones he uses.....
Do you know what Kram means.......the word not the personBorat, the second one......
Brake discs are soft. The braking surface may get a little bit of case hardening going on, but nothing a semi-sharp HSS drill won't get through without a little bit effort.saw someone selling these at a car show, they were amazing, bought one, took it home, it was carp, i imagine the discs have been heat treated or similar to make them soft
You've obviously never had a night in my company.The old dictum goes....
It probably is.
you like me will have been all star eye`d like a moth to the flame at TGThe one company that sells stuff that's too good to be true, is HMT. Their impactadrills and taps and reamers etc are very, very impressive. Have you ever seen a 14mm drill bit in an impact gun chew through 8mm of steel in around 10 seconds? And then do it again, and again?!
Unfortunately they come with impressive price tags, too...
I did the first bit, not the latter thoughyou like me will have been all star eye`d like a moth to the flame at TG...
then about 4 holes in gone "wow i can just about put all my weight on this pillar drill handle and it just cuts...."PINK" (snapped bit)"
their very good thou
done that plenty with cheap bits...
