BrokenBiker
- Newport, South Wales
I'll be making a toe jack adapter for my 20t bottle jack Saturday when I'm home.
Pretty basic design, 10mm thick baseplate, a length of 50x50x5 box welded to that, a bit of 60x60x5 box to slide over the 50mm, then a 60x60x6 angle iron foot welded to the bottom of the 60x60 box, and the same welded at the top on the back side for the jack to act on, maybe some gussets as well that will be 5mm thick
Simple design that will be prepped to give full penetration on all welds, the 50mm box will be bevelled half its wall thickness and a 1.6mm root gap on a bit of tig rod to help with getting everything square as well as get full penetration and probably tacked with the gasless mig flat out purely for ease but i dont want to use the gasless to weld it fully as im more confident with a stick welder for this sort of stuff, the mig can be deceiving if you arent spot on with it ...I know enough about lifting and use these style Jack's enough to know I'm well over the specs needed for the max 2 ton I'll likely ever lift (closer to 500kg actual lifting) but, that said, would you use a 3.2 6013 or a 7018? I've an inverter that will happily run a 7018 all day long, just don't have the rods (yet) but can order them to arrive sat morning, but i have 2.5 and 3.2 6013s already
