daleyd
- Wrexham, North Wales
While that’s great advice, and not beyond the realms of possibility I’d say it was “unlikely” to be the root cause of multiple failures in short space of time?Make a loose cotton cover for the machine and keep it on even when you're welding .
If you have it running and are angle grinding the boards will gert hit with metallic dust and Phffft bits get shorted, over loaded & fry There is even dust ingress when you're not using the machine.
A few months ago I took the covers off and was shocked at the dust build up in the wire feed box and on the circuit boards .
A quick de dust with the old vax and a soft brush sorted it . It now as well as the loose cover also resides under a half single cotton bed sheet that gets taken off before use & I made it a rule never to use the grinders .... bench or hand for half an hour before welding or during a welding session .
3yrs ago I'd planned to make a fully enclosable box on the 15 inch dia turntable it sits on , using the air-conditioner panels and fine fibre wool or paper filings .. but life got in the way
