Jaeger_S2k
- Highfurlong, Blackpool. Lancashire
I was just looking around, as channel 5's signal was pants and found this, admittedly it's from across the puddle, but .....
Now having seen what some have down with compressor farms
Who's had a go at this?
From contributor J:
Here is a very simple and crude way to make your very own rotary phase converter for $53.00.
First buy a used three phase motor which typically runs about $10 per hp. Second, go to the hardware store and buy a lawnmower string (seriously!).
Run your single phase power to the motor (2hots and ground). This needs to be a switch or a plug so you can turn the motor on in an instant. Splice the power leads from the machine you want to run into these wires. Connect the third leg from the machine you want to run to the third leg in the motor.
To start your phase converter, wrap the lawnmower string around the shaft of the motor, and pull on it just like you would to start a lawnmower. While the shaft is still turning fast, either plug the motor in or flip the switch.
The motor will run on single phase power. Your lawnmower string took the place of the capacitors that commercial phase converters have wired to the third leg. Somehow, once the motor is running, it generates the power in the third leg.
I know this may sound strange, but it is not very different from your $1400 phase converter. They are nothing more than a typical 3ph motor, a switch, and a capacitor bank wired into the third leg.
I used this setup to run a 7.5hp inverted pin router until I had a shop with three phase. I learned this trick from a guy who had a machine shop in his house. He used this to run his CNC mills and lathes.
From contributor W:
Contributor J, you are 100% correct - your setup *will* run a 3-phase motor. However, there are a couple problems with creating 3 phase this way:
1) Without proper capacitors, the three legs will be *very* unbalanced, both in terms of voltage and current draw, resulting in an uneven load on the machine's motor windings, less than full HP availability, and possibly premature failure of the machine's motor.
2) Without a proper isolating means (disconnect or plugs), circuit protection fusing, and motor running over current protection, don't let your insurance guy or the local inspectors see this arrangement!
I don't recommend that anyone who is not comfortable with electrical codes try to build and install their own converter.
Contributor J is correct in that you can build a 3 phase converter for low cost. The shop I worked in used one for 15 years. What he forgot was that if you wind your rope around the 3 phase motor backwards. your machines will run backwards.
