I’m wanting to run a single phase air compressor (sgs 90l belt driven) from my van. It comes with a fitted 13amp plug so it’s ok to run from a wall socket. question is how do I get it to run from a extension lead as it can bump upto 16amps when fires up so I’m guessing I may need thicker wire on extension lead ? specs of extension lead I have are ~ Max unwound 3120 watt 50 meter 13amps 240v. Compressor says it’s 13amps 230v 2.2kw 3000rpm. will this extension lead be ok as I know can burn motor out not having the right set up thanks??
trips going off fuses blowing
