clueless77
Not the usual star or delta question. Motor is a 3 phase dual voltage 3.2 hp AEG motor on a lathe.
Got an inverter after making sure motor was dual voltage, then opened the wiring cover on the motor and well, FMG. Was expecting the same as all the threads i'd read but got this. I was hoping to just wire straight to the motor. The 3 diagrams are what I found under the motor connection cover. I know one is the star/delta and reversing connections, one looks like the motor t.o.c and the other is the motor braking. Question is, what do I need to do to just wire into the motor?
Is it just a case of pulling all the wires out and wiring up to the inverter or will I need to bypass the other terminal block connections? Any suggestions would be really appreciated. Cheers.
