daleyd
- Wrexham, North Wales
Sorry mate but not much of that is true. Inverters usually have a ramp function programmed in because it puts everything under less stress, but if you wanted to you could have an almost instant start up, but most applications don't require this.personaly my preferd option would be to resell it and buy the right machene.
my 2nd option would be to fit a 3 hp 2.2 Kw singel phase motor ( sigel phase motors allways seem to need to be bigger than theer 3 phase mates when it comes to starting up as they struggel with torque compared to a 3 phase )
the absolute last option would be a VFD, the functionality just isn't needed, it's something extra to go wrong, ( tho this motor can not all motors can be configured to 220v 3 phase ) VFD's and electricity meters i've had it where i'm not sure what was going on but the meter was clocking up a fair rate faster than it should have for some reason. also the vfd will need to be bigger than you think for, 1.5 KW motor on a 1.5KW vfd dosent allways work going to need more like a 2.2 kw and even still may run into starting problems.
motors pull a hell of current during startup that a vfd can't supply so they tend to have soft start, but a compressor needs to get to working speed quite quickly, enertia is needed in teh flywheel to somooth over the compressions else tehy can stall when pumping at pressure, compressosrs have a small resovor ( usally the pipework between the NRV on the tank and the compressor itself also used for cooling the air, this pipework is drained down when the compressor shuts off, this volume gives means teh pump is only outputing at low pressure to start with and gives teh motor chance to get upto speed before the pump starts presenting much resistance
Lots also have a torque boost feature for starting, providing much more torque than you get out of a normal motor start, much more controllable too.
