mike os
just a little insane.....
- North Wales
just mounted a "new" (to me) 3 jaw & dialled in a piece of bright mild steel rod, I am looking at about 0.3mm/0.011inch runout ( checked with a drill shaft & its the same)
backplate register is bang on, and less than 0.01mm runout, turned on the lathe.
Should I worry? or is this about right ( bearing in mind second hand chuck on a roundhead student)
obviously I could turn down the register, but don't know if it is going to allow me to improve matters or not, the register is there for a reason
, just needed to machine a spacer to adapt the 2 together, 15mm plate now 7mm thick at the edges but really pleased to have made it so accurate as having struggled with the old chuck I was not sure if the headstock was on the way out.
