Just realised that we have hijacked "projectsj" thread...ooppss.. sorry dude!!
argoshield heavy = more co2 = more penetration...
you can run .6mm wire all the way up to 150-160 amps but ONLY if your feed motor will feed fast enough to deliver the required current. Remember, wire speed = current control, voltage settings are exactly that, change the circuit voltage. Remember, mig uses a constant voltage or CV powersource so your open and closed circuit voltages are the same.
I use .6mm solely in my 160 amp mig on 1/4 plate as it means I only have 1 roll of wire to worry about.
I'd stick with argoshield light as well as you won't see much of a difference between that and universal or heavy on 3-5mm plate.
As for welding 10mm plate, personally I'd move away from mig for this thickness and use DC MMA with 7024 rods for downhand or a decent quality 7018 for positional.
H
i guess i can offer my 2p worth of info in an attempt to try to provide some help.
1stly, gases such as Helium, Neon, Argon, Krypton, Xenon, Radon are known as noble gases (see periodic table, last column on the right from top to bottom type periodic table in google...). They have been called "noble" because they don't interact with any other elements / atoms we know of.
2ndly steel, no matter what form is based on iron ore + carbon. Co2 is basically a carbon gas. Steel and CO2 will interact no matter what you do to them (even if you do nothing they will intereact). You can actually see that because you will say that your weld is "dirty"..well that's because some of the CO2 molecule from your gas have been mixed with your Steel Carbon and are showing in your weld.
Some of you may be familiar with "oxide jacking" well that's CO2 and Carbon reacting in a steel environment creating carbon oxide jacking (CO)
Now the amount of interaction will depend on the steel you are using (assuming CO2 is CO2 regardless where you get it from) but in the field i work in we have high carbon steel with 100% CO2 to minimise interaction as the high carbon steel is pretty much "saturated" with carbon. (but we get oxide jacking)
CO2 is a very big molecule compared to noble gases and others in general, so i would be incline to believe that thin steel will be more prone to "Carbon poisoning" if welded with CO2 rather than thicker steel (using the same kind of steel of course)..
