Hi,
I was always under the impression that c02/Argon mix was best for welding steel.
However, Someone told me that if its not thin sheet metal (steel) that I should use pure c02 on metal thicker than 2mm. I will mostly be welding steel from 3 - 5mm thick.
Any suggestions...?
Also, What is the best wire to use for these thicknesses (3-5mm steel)? 0.6 or 0.8...?
Thanks very much in advance!
Ben.
Any suggestions...?
Ben.
