Mid Wales welder
Welder coding and NDT services
- Powys, U.K.
Unfortunately I work for someone so machining is out of the question as that would mean cutting into there profit which apparently there not making much of, the drawing requires a 10mm continuous weld will try welding the opposite side and let you know how I get on it's probably the only option available to me. Kent no point speaking to the so called clever engineers the last set of mounts I made was from 15mm plate with only two 10mm wings welded to it to attach it to the tracks sometimes I wonder how these engineers get a job. Will try a little of everything mention and get back to yous. Thanks everyone for your replies appreciate it. CT
Place I used to work the engineers didn't have a clue what the welding symbols meant! They would just put 6mm Fillet all the way round on everything. Always worth asking.
