slim_boy_fat
- Scottish Highlands
Any ideas?
Chain and an engine hoist? Unless you have a mate/neighbour with a small digger [or JCB]?
Any ideas?
Done may more holes, the borer siezed after a couple mins of full throttle, Im guessing overheated?! looking down the ports the piston is scored. Gave it some oil and a wiggle, it turns freely. Will it do any damage if I continue to use it? or best to get a new piston kit? will I need new barrel?
Need to do 3 more big holes this week. We have done 2 big ones and about 20 small ones.
Thanks.
The instuctions say 25:1 so I measured 500ml petrol to 20ml 2T oil, shaked in a small bottle and half poured in the tank. I think it might have overheated but Im told it must have been running lean. Some of the bolts were starting to rattle out incliding the intake so thats possible..I don't personally trust the 'proper' mixing bottles...
I use a kitchen jug thing with the graduations on the side to measure the petrol, and a syringe to measure the 2t oil.
Don't listen to what I say though, I don't do it very often so I probably don't know what I'm talking about
(I do 5 litre batches, that lasts me a few full days - had one strimmer running off my mix for 3 years now, petrol long reach hedge trimmer 18 months, another strimmer just over a year, couple of seasons with a blower, sporadic usage of disc cutter and chainsaw - oh, and everything gets 40:1(5,000ml petrol : 125ml oil) whatever the cap says and lives with it because I cba messing with different mixes)
Most of them do similar (iirc stihl don't say to double, it's 50:1 with their oil or 40:1 with others).
I had a mcculloch strimmer years ago that said 40:1 with their oil or 25:1 with others...
I will say my stihl strimmer is the most finicky, I had to tweak the tuning to get it running right on 40:1 - that said I bought it used and have never tried stihl oil in it...
I honestly can't see why it's an issue on anything remotely modern - older engines that relied on a bush sealing the crank needed 15:1 or 20:1 of 30 weight oil or they lost primary compression and didn't run right, if at all. Modern stuff with rubber seals and more efficient bearings though?
If I'm completely honest I'm not even that picky about the accuracy of mixing - I'll aim for about 40:1 but I'm quite sure I just as often end up with somewhere between 35 and 45:1 with no ill effect.
As long as you use decent 2 stroke oil designed for the right type of engine I really don't think it makes a noticeable difference.
get the petrol auger,5 mins a post,never had any problems
Just take the head off and check, replacing a t/s head is simple, just a new gasket. Seems like your cylinder is knackered though by your description. I would stick by the manufacturer premix recommendations.
As theres no head, the base gasket is the green gasket paper type which I assume I can make up myself as I have some or cornflake packet if I didn't?
