Blue Chips
- Maine, USA
I haven't posted for a while (too many and boring reasons to mention here), but I'm finally getting back on my M37 restoration project again.
I've found that by breaking a project up into manageable sub-projects I can get a better feeling for progress made, not to mention getting some 'closure' once in a while.
I decided that my next 'sub-project' would be the instrument panel. Here's how it looked before working on it:
I decided to restore as much of the hardware as practical. Since the rust was just superficial, I bead blasted a number of parts in preparation for zinc electroplating. Here are a few parts ready for plating:
Some parts in the zinc plating bath:
Some parts after plating and passivation coating:
After plating, the instrument cluster lights were in excellent condition except for the wires and the ends of the rubber boots that seal the wire coming out of the socket. Rather than replace entire light assemblies, I replaced the wiring with the proper mil-spec wire, installed closed-cell EPDM foam seals (cemented on with Loctite 480), followed by heavy-wall heat-shrink tube. I made sure that the wire could still slide in and out of the lamp socket through the foam seal so that it would not affect the spring pressure of the contact against the base of the lamp.
I replaced the old light bulbs with LED lamps. However, these turned out to be too bright. More on that later.
