In domestic applications 1.5 is typically used for lighting circuits and anyone using it to wire a 16 amp cicuit is mental !
The whole point of using cable overated for the circuit is to give a generous safety margin.
no diffrent to a broken leg in a ringmain carrying 30 amp on a piece of 2.5mmits a fault that happens as regular as clockwork
not good but who am i to say i dont make the regs just adhere 2 them. thats the downside to ringmains
and it would also appear as though the mods dont like there members being told to keep to what they know instead of giving out bad advice on something they obviously have no clue over...
just remember, get it wrong and it probably will be some innocent person who is killed instead of you.
and that is the reason why all domestic circuits are covered through rcd protection . any leakage to earth even if the earth wire is broken will cause current imbalance and trip the circuitall ring circuits have that design flaw. on the plus side, if it was the earth, then there would still be an earth. this is why you should have an electrician check the wiring every 5-10 years
If you read the posts, all the suggestions are erring on the side of safety, your comments are suggesting 1.5mm² would be acceptable (under certain conditions) this may lead to the less knowledgable putting themselves at risk.
i sugest u go wire your own house without one then if thats what u want to dothats not the reason why RCD's are used. though it is an additional benefit by it being there. if i really wanted, and taking things to the limit, i could wire a house without any RCD's and still comply with regulations
justmake sure u dont use any outside equipment theni said i could. i didnt say i would. and my house only has an RCD on the kitchen circuit. nothing else in the house is RCD protected.
unless its plugged in to your kitchen
justmake sure u dont use any outside equipment thenunless its plugged in to your kitchen
