So that unit will have a main 'on/off' and then i need to add in a MCB? In which case i may as well add a 'garage unit' which already comes with the MCB.thats just a double pole mainswitch the 2 way means it will accept 2 minature circuit breakers.if u have a 6mm cable feeding your garrage fit a 32 amp mcb in that unit
The CU in the garage has a 63amp RCD protection. I never expect to see that sort of usage as only using one power tool at once. But should the MCB in the house not equal that value?
