As someone whos also not a spark, can you tell my why not?I am no spark, but i can tell you you can't take a 32a socket off a ring main!
That is true. Infact ive actaulyl got a 50m reel in my room now which has come from the uni motorclub garage after someone used a welder on the end of it with only half of it paid out.A warm plug won't be the problem you'll experience if you use the extension lead unwound...
Another ancient thread you've dug up here.
What, this thing?
The biggest fuse that you can fit in a 3 pin plug is rated at 13 amps so it can only handle 13 amps, not 16.
If you need to draw 16 amps then you need a 16 amp supply, simple as that.![]()
Another ancient thread you've dug up here.![]()
