Got a reasonably sized job coming up, for which I can justify a new welder (involves walking to site with kit, so want a smaller, lighter welder). Does anyone have any experience with a dual voltage welder? Like https://www.weldingsuppliesdirect.c...xts-163-dual-voltage-mma-welding-machine.html is there any reason not to go for a dual voltage machine - I do a fair bit of site work, so not everywhere has easy access to 240v, and some sites don't allow 240v at all. However, I have always managed before, so it isn't a deal breaker either way, I just thought it might add some flexibility for me.
There's no disadvantage to getting a dual voltage welder. Just remember that if you have a lower input voltage you'll need a higher input current i.e. the Parweld XTS 163 DV you linked will run on a 16A 230V plug but if you switch to 110V you'll need to stick it on a 32A supply. Also, most dual voltage machines will have a limited output on 110V. Usually you'll be able to run a 3.2MM electrode on it though.
