Paul G
Hi All.
I have a 1ph, 200amp welder, and up till now have run 0.8 wire and CO2 gas.
It has 8 voltage steps and the makers plate states a voltage range of 15.5v to 22.5v.
On setting 6, (assuming 1v steps, that's 20.5v,) 0.8 wire tends to burn off well but on 7 & 8 burns off
at what seems to be globular transfer.
I'm contemplating trying 1mm, but before I lash out on wire and a feed roller I thought I'd ask on here
if anyone uses, or has tried it, on a single phase set.
If it works then it would just be for the odd job that crops up as the 0.8 seems to cope with every thing
from car bodywork to a 6mm fillet on 6mm plate.
Many thanks in anticipation.
Paul G
Paul G
Failed
